wtf, no power???
Old Apr 14, 2007 | 01:12 AM
katinkid's Avatar
Default wtf, no power???
unhooked battery to reset ecu. for about 3 hours. pos and neg
plugged them in again, and only the cabin light turns on.
i put my key in ignition, and it wouldnt start!!!
i leave key in on position for like 2 min and radio lights up. and car has power.
so i turn my headlights on, and the whole car shuts down, back to phase 1. wtf.
am i supposed to wait a certain period of time before restarting car???
what is the process of reseting the ecu. i left my key in there again for about 5 min but nothing else happend.
Old Apr 14, 2007 | 01:23 AM
Default RE: wtf, no power???
Will it not even start?
Old Apr 14, 2007 | 02:23 AM
sounds like a bad connection on the battery terminal. Check the terminals for corrosion. If they are bad thenjust replace them. Its pretty cheap.
Old Apr 14, 2007 | 03:55 AM
katinkid's Avatar
car wont even start, headlights wont turn on, sunroof doesn't work,
only the door dinger thing, and the cabin light!!!
idk. looks like i went backwards trying to fix my car today!!! this morning it ran like ****, and now it doesn't run at all, lol
Old Apr 14, 2007 | 06:48 AM
Kaede.Noir's Avatar
some of those symptoms sound like low battery, but other sound like a short.... is your battery fully charged? and if not, did you check the corrosion like eng said?
Old Apr 14, 2007 | 07:28 AM
katinkid's Avatar
yah it looks fine. i mean the car turned over right before i disconnected the battery, to recet the ecu. there should be no problem with it. but there is.
Old Apr 14, 2007 | 08:53 AM
racerx55's Avatar
take the terminals back off and clean them, then try again
Old Apr 14, 2007 | 01:53 PM
Check for a blown fuse.. or many blown fuses. I think the main 100A fuse is gone.
The reason for it idling like ****.. is that it needs to learn.
Old Apr 14, 2007 | 04:15 PM
katinkid's Avatar
no it idled like crap before i unplugged the battery, and i still cant figure out what that is. check out the other thread rough idle. im screwed if i dont fix it by tomorrow, i need to get to work. i rented an obd 2 code reader, so im really hoping that will help.
the car sounds like a diesel engine. wtf.
Old Apr 14, 2007 | 05:01 PM
katinkid's Avatar
well almost positive, that my battery just doesnt have enough juice to start my car.
