2000 eclipse 2.4L injector problem please help
I just recently bought my wife a 2000 eclipse 2.4L witha 5spd manual trasmission. When i bought it i noticed that the engine was misfiring so i checked all the sensor plugs, coils, spark plugs/wire, fuel and nothing. What i did notice is that when i unplug the injector that is next to the battery the car runs the same. I replaced injector and still no luck. Anyone have an idea or suggestion? I did notice rpm guague flickering to high rpms when idle
From checking every possible problem i finally went to the last resort. The ECU and guess what? It has 1-2 resistors burned on the board. My question now is, can i replace it with any other ECU from the same model even thou the coding on the case is not the same? MR420680 is the one i have currently. Would any MR work?
