2000 Eclipse GS Sunroof Problem
Hello. I am new to Mitsubishi Forum. I have a 2000 Mitsubishi Eclipse GS with 96,000 miles on it. The car has been good to me and quite reliable, but one problem I've been having for a while is with the sunroof. When I press the button to open it, the seal seams to stick and it won't open. I have to push it up with my hand and hit the switch again. Has anyone else had this problem and figured out a way to fix it? I've experienced some of the other typical 3G Eclipse problems as well such as the cracked dash, melted wiring harness for headlights, and blown out center speaker, but I've found solutions for most of these.
RE: 2000 Eclipse GS Sunroof Problem
Honestly, I haven't found a solution for that either, I always thought it was a short in the wiring becuase it always "stopped" after it had rained, but now it does it almost all the time. and if you haven't already don't bother replacing that center speaker. it's not worth it, just disconnect it.
jthorn75
06-04-2012 04:18 PM
