2001 Eclipse GT Cruise Control Problem
Old Feb 13, 2006 | 11:20 PM
ictponder's Avatar
Default 2001 Eclipse GT Cruise Control Problem
When i push in the button, the green "CRUISE" indicator turns on. But, when i try to set the cruise with the lever...nothing happens. I just bought the car (fully loaded) and would really like to have cruise as I have driven a 94 Dodge Shadow for 6 years with NO options. Any help would be appreciated.
BTW: I've searched forum for an answer!
Old Feb 13, 2006 | 11:37 PM
Default RE: 2001 Eclipse GT Cruise Control Problem
Just a stupid question but when you hit the lever you are putting it to set and not resume, and also do you let go of the gas once you hit the lever. These are just to make sure its not something stupid. Like most problems are
Old Feb 14, 2006 | 02:40 AM
Sanguinius's Avatar
Also if you even touch the brake or clutch it'll cut the cruise off. You may need to hold the set for a few seconds to get it to set (My mom's old caddy took a few seconds before it would set but my sentra does it in no time at all).
Old Feb 14, 2006 | 03:05 AM
Joel_CA's Avatar
Check the vacuum hose at the cruise control actuator pump and at the cruise control diaphragm atop the throttle body. They can pop off quite easily.
Joel, CA
Old Feb 14, 2006 | 05:38 AM
Sanguinius's Avatar
I didn't realize that the cruise was vaccuum controlled... I always thought it was purely electronic... Thus the reason I don't deal with cruise in my vehicles lol.
Old Feb 14, 2006 | 08:43 AM
wow that is strange that its vaccuum. I thought it was purely electronic too.
Old Feb 14, 2006 | 07:17 PM
ictponder's Avatar
Where is the actuator pump? Also, I don't see any hoses unplugged near the throttle body.
Old Feb 15, 2006 | 11:49 AM
Tearstone's Avatar
ORIGINAL: ictponder
The actuator pump is built into the throttle body. The big huge brass looking bell is the vacuum actuator and you can follow that vacuum line all the way over to the far passenger side of the vehicle where your cruise control module is. I don't have a 4cyl on hand to take pictures but I can point you in the direction of the FSM if need be. Let me know!
Old Jun 19, 2016 | 01:32 AM
BlackGTS's Avatar
Default how to check cruise control
Joel, CA
My cruise control did not work so I did the following To check actuator located by the throttle body pull hose from pump suck air from hose if actuator moves it's good make sure suction is sustained if not you have a leak in your hoses I had a leak replaced hose cruise control works perfect
dkmiller222
Aug 1, 2018 02:45 AM
3dhunt
Jun 17, 2009 09:21 PM
embolaras
Jan 23, 2008 07:48 AM
KasiNovaH
May 18, 2006 03:08 AM
alexlook
Dec 25, 2004 01:56 AM
