3G doesn't Start After 3 Weeks Of Winter Parking
Well, here's what I see. I don't believe it to be the alternator either.
If, by removing the relay and jumping the two terminals, you get fuel....don't you think that the relay is the issue and not the ECU? The ECU isn't the endgame, it's the mediator, the middle man to most systems.
ORIGINAL: racerx55
Sorry, but thats just way out in left feild of a bad guess. Cars will start and run just fine with a bad alternator if you jump them or have a good battery in them. It will just go dead after a short time of running.
From what i understand it wont start, it just cranks over slow and the lights only dim.
It could be the alternator, if its locked up .. 3 weeks of sitting shouldnt hurt anything unless it froze up and the water pump cant turn.
With mine, I was running two 1k watt amps with no caps... eventually it ate up the alternator... which still worked but wouldnt charge the batt. correctly, and didnt power the car right at all... I may be way off... but the conditions seem rather similiar (as Im in MD right now, where its like 40 degrees in the sun) I ended up replaceing the alt. and batt, everything worked fine then... (P.S.- I bought a few caps this time too, lol.)
GSXEX Knubbe
May 18, 2007 07:57 AM
