ATF Fluid Question
Old Nov 17, 2008 | 06:13 PM
Greg8325's Avatar
Default ATF Fluid Question
I just changed my ATF for the first time in my 2002 Eclipse. My question is that it's been about two weeks now and I decided to check it again. I opened the hood and did a quick check with the engine being off for about 2 hours. The ATF read high, not ridiculously high just a little bit above the marks on hot. Then I ran the engine for a while until the temp was right in the middle, tried to get my car about as level as possible then checked again. The ATF read just right below hot. Am I good?
Old Nov 17, 2008 | 08:03 PM
Dusty Eclipse's Avatar
Default RE: ATF Fluid Question
You should be fine.
Old Nov 17, 2008 | 08:15 PM
Greg8325's Avatar
Thanks. I was worried. I read online about if you have too little or too much your transmission can have problems. I just wanted to make sure that I didn't need to add or remove ATF.
OutlanderGT
Jul 13, 2018 09:28 PM
nesser
Feb 15, 2017 05:35 PM
Bob Loblaw
Nov 8, 2012 05:10 PM
2k1monterosport
Feb 16, 2011 10:47 PM
chrisacain
May 29, 2005 10:31 PM
