Blocking EGR Tube?
Old Apr 7, 2006 | 11:51 AM
Trent's Avatar
Default Blocking EGR Tube?
On my 00 eclipse the guy before me put headers on it and removed the egr tube, when he did this he left the spot on the intake manifold open.......I made a plate to block it off but won't this cause the engine to idle rough?
Old Apr 7, 2006 | 03:51 PM
Sanguinius's Avatar
Default RE: Blocking EGR Tube?
The EGR tube isn't threaded into the intake? Hake sure you gasket the hole. You want it to be sealed. If it's not then you'll lose vac in the intake and yes that WILL dork things up and make you run like @$$ if at all.
Old Apr 7, 2006 | 04:17 PM
Trent's Avatar
By the way, that is what made the car throw the code......i'm not sure how i seemed to overlook the missing tube the first time I checked.......when i put the plate on last night i put a gasket on it so I hope everything is fixed now.......well just have to see if my light comes back on when I drive it.....
Old Apr 7, 2006 | 04:33 PM
Sanguinius's Avatar
Did you unplug the battery and reset the ECU?
Old Apr 7, 2006 | 04:38 PM
Trent's Avatar
I have a scan tool so I just erased the code.....
Old Apr 7, 2006 | 07:30 PM
DSMTalonAWD51's Avatar
the code will continue to reappear you cant erase it. but no, egr block off will not cauge idle problems
Old Apr 10, 2006 | 02:22 PM
Trent's Avatar
Sorry, i meant "clear" the code....not erase it from the system......
Old Apr 10, 2006 | 05:15 PM
Sanguinius's Avatar
If it comes back then you know that wasn't the problem lol
Old Apr 12, 2006 | 11:36 PM
ORIGINAL: Trent
i meant clear it too. if you clear the code, it will just come back on soon
wega
Sep 15, 2007 07:56 AM
95HGeclipse
May 29, 2006 02:26 AM
DixonsGst
Aug 9, 2005 12:23 PM
hellsheep
Aug 7, 2005 06:34 PM
monkey714
Aug 3, 2004 11:31 PM
