Bouncing idle issue
Old Mar 15, 2011 | 05:36 PM
snowmobiler168's Avatar
Default Bouncing idle issue
I have a 2005 Eclipse GT and when the car is stopped and idleing the RPM's will bounce between 400-1000 Rpms and it will change from 400 to 1000 Rpms and back at least once a second. im not sure what is causing this problem. I know it is not a missfire, because i just fixed a 6th cylinder missfire and its not even close to sounding like that. A friend told me his civic (i know its completely different) used to do that and it turned out to be a idle control valve? I'm not sure if that could be, any suggestions will help! thanks.
Old Apr 12, 2011 | 11:24 AM
kendalldwhite's Avatar
i also had a problem with my eclipse.. the same problem you had i looked it over and i found one of my spark plus wires was messed up melted down and crap so i changes it and it fixed it
Old Apr 12, 2011 | 11:25 AM
you also might try tuning your idle to i had to tune it myself when i put my intake on
scoathy
Jul 29, 2011 11:32 AM
OhioEclipse
Mar 23, 2008 11:00 PM
Cydric
Aug 30, 2007 09:39 AM
Ziggy
May 29, 2007 01:24 PM
Eclipsor
Jun 20, 2006 03:14 PM
