A/C problems
A/C problems
- I have a 3rd generation 2001 Mitsubishi Spyder Eclipes GS, 3.0 liter engine. I have about 150K on it. I have an erg valve problem that I think needs to be replaced. My other problem is that my A/C doesn't work properly. When the car is running or at idle with the A/c on, the car wants to die. The A/C just pulls so much from the engine it won't run. The little green light on the controller blinks when either the heater or A/C is running. When the problem started, I had a bad connection on my battery. This has since been fixed. That is when the idling problem started and the A/C problem started. It was blowing cold air after that It only blows warm or hot air. The heater works fine. I have a check engine light on constantly. The car runs great as long as I don't run the A/C. Can anyone out there give me a starting point to start my troubleshooting and to tell a mechanic where to start to get this fixed. Is this a vaccum problem caused by the faulty ERG valve?
Jim
p4c0
02-22-2007 06:36 PM
