dead spyder!!
Old Mar 19, 2007 | 08:29 PM
liljulia04's Avatar
Default dead spyder!!
I have an 2003 eclipse spyder GT!! I had to disconect the battery the other day so I could get into the car because someone stole my keys!! Now the car wont start!! Could it be my battery?? Or something else??
PLEASE HELP!!!
Old Mar 19, 2007 | 08:32 PM
Default RE: dead spyder!!
make sure the batery teminals are tight and not corroded
Old Mar 19, 2007 | 08:38 PM
liljulia04's Avatar
There looks like there is croding on top of the battery!!
Ill just buy a new battery and see if that works!!
Old Mar 19, 2007 | 09:15 PM
metalsaber's Avatar
If there is corrosion, just take connectors off and take some sand paper to the terminals and cables connectors to remove the corrosion. That should be all you need to do assuming the battery isn't dead.
Old Mar 20, 2007 | 09:59 AM
exactly as metal said. Just clean them off and see what happens. Also what is it doing when you try and start, are you getting anything, like trying to turn over, or is it just dead
Old Mar 20, 2007 | 10:03 AM
RCJr9186's Avatar
that's where i was going with it. does it click at all? does your light come on when you open the door? dont' go buy a 40 dollar battery when it could be some 5 dollar terminal connectors.
Old Mar 20, 2007 | 02:11 PM
liljulia04's Avatar
Its completly dead it doesnt turn over or anything!! When I open the door the door open light blinks and keeps beeping. It will start with a jump. But other than that it wont start.
Old Mar 20, 2007 | 03:40 PM
tjbiker031's Avatar
well make sure you clean the terminals first beforeyou do anything.you can use sandpaper, a small wire brush or simply go to the parts store and buy a battery terminal cleaner. the same thing happened to my car, and i cleaned the terminals and the wire connectors and it started right up.
Old Mar 20, 2007 | 03:58 PM
Dusty Eclipse's Avatar
lol, try dumping Pepsi on the batt terminals?
Old Mar 20, 2007 | 04:02 PM
brknhrtdpimp1489's Avatar
thats actually not a bad idea...pepsi is really acidic b/c of the carbonation lol it could work i would try it...its gonna be messy though lol
