eclipse swap
Old Feb 3, 2007 | 03:07 PM
Brockley's Avatar
Default eclipse swap
Need to know if a 1991engine, gsx,awd,turbo fit in a 1995 gsx,awd,turbo?
Old Feb 3, 2007 | 03:32 PM
RCJr9186's Avatar
Default RE: eclipse swap
yes, it is the same engine except for one fact, the 1st gen's came with a "6 bolt " and in the 2nd gens came with a "7 bolt" the 7 bolts had a major problem with "crankwalk" which is exactly what it sounds like, the crank literaly walks out of the casing... there are several theories to why the engine does this but nothing confirmed... you will need to get a 6-7bolt swap kit which you can get at quite a few websites. www.slowboyracing.com, www.cimotorsports.net, www.buscharracing.com good luck w/ the build
Old Feb 3, 2007 | 03:39 PM
are you serious??????
Do a search. This is only something that has been done at least 10453804975348750934094 times in the past lol
Old Feb 3, 2007 | 03:42 PM
there are more engines than jsut that one. you can even use some hyndia stuff
https://mitsubishiforum.com/m_42332/tm.htm read. there is alot more info out there than just this too...... just google it
tkloss@msn.com
May 2, 2015 11:49 PM
rstoevo
Jan 20, 2013 10:47 AM
holstisu
Aug 19, 2004 12:39 AM
Boomer
Mar 30, 2004 09:55 PM
TurboCharged
Dec 11, 2003 08:29 PM
