Flooding on passenger side floor of Mitsubishi Eclipse GS 2000 model
Old May 6, 2009 | 06:09 PM
irir123's Avatar
Default Flooding on passenger side floor of Mitsubishi Eclipse GS 2000 model
I have a Mitsubishi Eclipse GS 2000 car - last few months, every time it rains, water leaks in and floods the floor on the passenger side - I took the car to a body shop guy, who hosed the car and confirmed that the leak comes from behind the glovebox on the passenger side - took the car to a mechanic who removed the glovebox, but could not find any leaks on the firewall there - but he said the water seems to be coming from the left of the glovebox - how do I find it and fix it ?? the water has already messed up my audio system amplifier - the dealer tells me that diagnosis would cost $600 to remove the entire dashboard to look for any leak/hole on the firewall and anything further will cost more - is there a way I can fix it myself ?? thanks in advance
Old Jun 1, 2009 | 11:22 PM
jgbrules's Avatar
nope. gotta remove everything to see where its comming from. no way around it. sorry dude. i have done quite a few of those jobs. greg...
Old Jun 1, 2009 | 11:24 PM
Blck3G's Avatar
600 is very fair..I also had this problem-Heater core,Im a smog person we dont do AC work alot. So a buddy shop said they can do it for 1000 My reply...eff it I got blankets autozone.com has ALLDATA so check out the diagrams and info if you choose to take off your dashboard...If I can get it from work.We have Mitchell On Demand which has very details procedures.
Old Jun 17, 2009 | 08:37 PM
The heater core causes this on these cars and it is very comon on all 3G eclipse models. As stated before check the heater core
Old Jun 18, 2009 | 07:25 AM
irir123's Avatar
Hi - but remember, it floods ONLY and ONLY when it rains and not otherwise!
so do you still think it is the heater core that is causing this ??
Old Jun 18, 2009 | 07:59 AM
It could be a number of differnt things honestly. I have heard of bad seals in the door weather stripping and windshield and cracks in the firewall all from other types of cars, It is just that in the Eclipse 3G it is totally common on ALL of them that the Heater core leaks eventually.
here read threw this
http://www.club3g.com/forum/problem-...-problems.html
Old Jun 21, 2009 | 12:45 AM
jgbrules's Avatar
once you get the dash out your going to find that a seam in the firewall is leaking, or the windsheild seal is leaking. dont worry about the heater core.
Old Jun 21, 2009 | 10:11 AM
BrokeDad's Avatar
Yep .. dry it up and pour water on different areas and then look for it coming in. If it was the heater core you'd notice a distinct smell from the antifreeze mix in the water.
Old Mar 3, 2014 | 09:39 PM
chazspeedy69's Avatar
My sunroof is off balance I guess. Lole the left rear corner is higher then the other corners and when it rains it leaks and the water goes from the sunroof to the support beam down it past my dashboard to my floorboard. Could my sunroof be aftermarket or no? I had my cuz and my bro look at my car and one says its not aftermarket one says it is.
irir123
Jan 26, 2011 12:12 AM
gfowler55
Sep 12, 2010 09:05 PM
rsevelin
Jul 28, 2009 10:41 AM
bishigt_18
Nov 1, 2008 07:24 PM
barbalicious
Nov 27, 2006 07:04 PM
