great ideas, but NEED MORE CLUTCH HELP
Old Dec 13, 2005 | 03:53 PM
estraw's Avatar
Default RE: clutch??? PLEASE HELP!!!!
that can't be the case though, cause i replaced everything that touched the firewall. it's like there's not enough fluid going to the release cylinder. i think that might be what i have to replace though, i'm gunna go buy it and try that out, if that does'nt work, then i dunno
Old Dec 13, 2005 | 06:10 PM
get435's Avatar
It is very unlikly but the new part may have issues. because the piston in there sould push enough fluid to push the rod on the slave to the throwout berring in the tranny. so the fluid is going somewhere wether piston in the mater or slave is not working is the case because there are no leaks so i seal on one has been blown.
Sanguinius's Avatar
Just make sure you bleed the system thoroughly. Air bubbles are a BAD thing LOL.
Old Dec 14, 2005 | 12:12 AM
estraw's Avatar
ya i've probly bled it about 6-7 times since i started having problems with it. that was a waste of $4 worth of brake fluid
Old Dec 14, 2005 | 03:18 AM
Sanguinius's Avatar
No no I mean when you replace the slave cylinder be sure to bleed it quite well.
Old Dec 14, 2005 | 08:06 AM
estraw's Avatar
i know, i was just saying that i should be pretty good at bleeding it now
Old Dec 14, 2005 | 03:42 PM
spf2000's Avatar
a pictue of the clutch assembly:
[IMG]local://upfiles/6053/00D587097A2E49E8AB5D20A58C98EC3A.jpg[/IMG]
Old Dec 14, 2005 | 08:45 PM
estraw's Avatar
Fixed it!!! thanks for the help everone. replaced the slave and master cylinder (slave cylinder (or release cylinder) by the tranny and master cylinder by the firewall. thanks again for the help
Old Dec 15, 2005 | 06:47 AM
Sanguinius's Avatar
You're welcome glad we could be of some assistance.
earthspresident
Oct 26, 2008 11:56 AM
theddy
Sep 20, 2007 08:24 PM
t.i.eclipse
Jul 19, 2007 09:23 PM
anthony_piaa
Apr 26, 2007 05:42 PM
