GT Gas?
Old Aug 20, 2007 | 10:05 PM
Default RE: GT Gas?
No ****
Old Aug 20, 2007 | 10:26 PM
Default RE: GT Gas?
both versions of the3g 6g72 REQUIRE at least 91 octane. if you use less and like putting the pedal down hard youll regret it at some point plain and simple. I did in my GS I had before my GT and guess what when a rod flys out of the bottom of your block it is not a pretty site. that is extra abuse on the motor and it is even worse for the GTS versions
Old Aug 20, 2007 | 10:33 PM
Default RE: GT Gas?
ORIGINAL: Dusty Eclipse
Dude, Sebs 110% right here, on both things. The car was DESIGNED to use premium fuel. Trying to run anything else will even in most places VOID your warranty (to a point). He also correct in this being a MAJOR reason why Mitsus (especially eclipses of the 4g63t vareity) get a bad rep.. you know how many idiots I knw running **** (87) thru thier t/c'd motors? Thats terrible for the car. It may not seem like it now, but I can guarentee that over time it WILL cause a problem. To those of you claiming that your car doesnt say its prefered fuel, that is likely. Remember that it was a STICKER on the inside of the fill cover, and a LOT of dealerships (mostly used cars) pealed them off (or never installed them to begin with) as to make it seem to run 87 thru em, that way they seemed cheaper to own and fuel. When people brought them back to Mitsu "under warranty" they claimed that the consumer peeled off the sticker, and they were thusly NOT liable for the damages done to cars. deadeclipse.com had a thing about it, and Ive heard of it happening. (Not just on Mitsus either, Benz, Ford, Lexus and a few others.) But TRUST me, those cars GT/GTS and the GST/GSX MUST run premium.
Well you should first of all know your car when buying. ok so a sticker is missing well your owners manual tells you/ and on top of it the stickers are now on the inside of the fuel door and they are stamped on the filler caps so it cant be removed in most cases these days. the reason in the GT and GTS it is vital is because your stock pistons suck big *****. and cant take any type of heat. well inase you guys did not know 87 octane creates more heat apon burn than 91 or 93. The stock pistons on your cars SUCK and they melt easily its been a known fact from square one with them.
incase anyone wants to polish up or learn what exactly lower octanes will do to your motor please read here https://mitsubishiforum.com/m_42371/tm.htm this is the entire reason why I posted this write up to begin with
Old Aug 20, 2007 | 10:39 PM
Default RE: GT Gas?
I remember reading that. I quote from that all the time
Old Aug 20, 2007 | 11:04 PM
Dusty Eclipse's Avatar
Default RE: GT Gas?
Nice, couldnt ave said it better myself
Old Aug 22, 2007 | 09:44 PM
ba3kgt's Avatar
Default RE: GT Gas?
would this stuff still happen even if you dont drive at high rpms cuz im just tryin to save my parents some $$$
Old Aug 22, 2007 | 10:14 PM
Default RE: GT Gas?
It will happen regardless what you f-ing do
Old Aug 22, 2007 | 10:47 PM
jlh077464's Avatar
Default RE: GT Gas?
Dude in the long run it will save them money for buying the 91+ octane
Old Aug 22, 2007 | 11:50 PM
Default RE: GT Gas?
what about when they have to buy a new motor
Old Aug 23, 2007 | 12:13 AM
Default RE: GT Gas?
Seb, hes agreeing with us. Hes saying it would save $ to just buy the 91 and up.
