Hand Brake Swap
Old Apr 23, 2008 | 05:37 PM
trace009's Avatar
Default Hand Brake Swap
Is it possible to swap the OEM hand brake for something like this: http://www.motorsportworld.co.uk/fra...ke-handles.htm
Also, does the manual shift *** just unscrew and does the trim around the shift boot just pop out or do I have to remove the center consol and come in from underneath?
Both questions relate to a 2001 Eclipse GT V6 with a manual transmission.
Old Apr 25, 2008 | 12:38 AM
PoolhallJunkie777's Avatar
Default RE: Hand Brake Swap
yes you can but make sure the hand brake fits. first of all the cover for it just slides off. when i bought mine i had to bore it out and it sitll didnt fit so i gave up.
the shift **** just unscrews. (rightie tightie, lefty loosey) the shift boot should come along after that...but i dont remember. if the trim snags it just pop that off. if it doesnt pop off, i wouldnt even worry about the boot...tearing out the center console is not worth it you will break a fastener.
hope this helps
pilcan
Jun 30, 2009 01:58 PM
gst4me
May 18, 2006 03:42 PM
keats
Jan 20, 2005 03:59 PM
keats
Jan 9, 2005 04:03 PM
HotNix95gsx
Sep 23, 2004 01:33 AM
