Help fast please ! short problem?
Old Apr 12, 2011 | 09:14 PM
thy ace's Avatar
Default Help fast please ! short problem?
3g eclipse gt 2001
New battery / new alternator yet is still shows a start of 6-7 volts output and then slowly lowers until car dies....
Here is the story....
I was hooking up an amp in my car to a successfully hooked up jvc stereo...made sure all grounds were independently grounded to the body of the car. Power wires for the amp was off the old amp that normally comes stock...wired it up to a switch for the amp turn off / on. Used RCA jacks on the back of the stereo for rear left and right. I did not use stereos basics rear speaker wires.The eq is powered by the same wires that power the stereo and has worked great for the last 6 months.I was not getting hardly any sound out of the speakers from my amp, then it happened..the battery was dead.
I have started the car and let it charge through out the whole set-up of the car stereo...oh forgot ..was using eq for rear speakers and moved eq to run off of the front r / l . So after hooking the eq up to its new speaker input and starting the car to adjust the channels.Nothing was wrong...hooked up the amp as I stated and the car is now dead.The alternator did go bad and was replace today , but it still does the same thing.
As I thought it was the alternator, I received a jump start and it showed the same signs as before.....soooo, I thought I might have caused a short somewhere in my wiring , either speakers or power.So in a panic I disconnect all power from my radio / eq / amp , this way, if it was a short I did while wiring, it would prove to be my mistake or something else.
All power is now disconnected from all three things and no difference was made.
Any thoughts to what is causing the car to not charge and die?
I have looked over all fuses , no problems, examined all wires under the hood, nothing has changed or even looks remotely close to being shorted out.
Desperate for a quick reply / answer as I need to fix it and head to work in a little over 24hrs.If there is a solution ..I will even try to fix it in the dark tonight.
Needs help fast with no money > used all I had to replace alternator,
Thy Ace
Extra information:
The only thing on the car unplugged from stock is the hazard button.
Dash gauges do not work now either > fuses are good both under hood and in side panel.
Battery has no power drain when it is off.
Old Apr 13, 2011 | 05:00 AM
thy ace's Avatar
My next step is removing all fuses that are not needed for the car to run in the side panel area to see if it is wiring inside the car after the fuse box. If that does not change things then I am going to remove fuses in the engine area that are not needed to run the car.
I am hoping this will narrow down my hunt for the cause of this possible short or change my thought to focus on something else,
Still looking for ideas on what might cause this......will post my findings.
Thy Ace
Edit: Findings so far....Tried all lights external ..all work when jumpers are attached and unattached until car dies.
All fuses pulled on the side fuse panel..all but ignition and relays > not the problem
All fuses pulled in engine area....all but relays and some of the lights and of course ignition / engine fuses.
Still have problem with the voltage dropping until the car dies
Inspected all wires in engine are that are open , did not open up the stock routing cases or unwrap the wires going through them.
Any ideas would help greatly..
Desperate for a solution ...no money need serious help so I can get to work in 16 hrs
Old Apr 13, 2011 | 03:04 PM
thy ace's Avatar
Found the problem after a headache and finding a ride to town...
The answer to this problem was...... the new battery proved to have a short in it , which only appeared after putting a heavy charge load on it. The heavy charge load was from me running basically my amp / eq / radio and accidentally turning on the fan...never noticed it at that time, since I had my radio blaring.
So if you think it is new or just replaced and was not replaced that day after testing it 1st....chk it again before you panic as I did.
Thy Ace
captawesome385
Jan 25, 2009 04:21 PM
ShortyRider
May 27, 2008 09:30 AM
ProjectDrknss
Aug 9, 2007 01:39 AM
Dreamer13
Jan 17, 2007 10:51 PM
estraw
Sep 30, 2006 12:22 AM
