How to remove counter balance shaft mitsubishi 2002 ecplipse
Old Oct 10, 2015 | 10:45 PM
leen's Avatar
Question How to remove counter balance shaft mitsubishi 2002 ecplipse
I have already removed timing belt and that timing belt B (which goes over that balance or counter balance shaft ...not the oil sprocket ) ...now obviously the counter balance shaft is rotating with the screw...I actually found that previous owner/mechanic did a mistake and that mark was not aligned with notch on the block..so I want to see the condition of shaft and bearing and if that makes noise ...
Is there any other option than using that special tool MD998785 to hold the shaft while I remove the nut
xav6ier
Jan 20, 2007 04:52 PM
ryapyuco
Aug 23, 2006 04:16 AM
n2daizo123
May 16, 2006 08:17 PM
93eclipsegsx
1st Generation
Mar 5, 2006 12:13 PM
EclipseGSRoadRacer
Oct 5, 2004 05:54 PM
