Keyless entry
Old Aug 6, 2005 | 01:29 PM
Battery's Avatar
Default Keyless entry
Hi everyone,
I have a 2001 Eclipse GT and recently I have been having problems with the keyless entry system. At first I just thought it was the battery in my remote so I went and replaced it. But it still doesn't work, so I tried the backup keypad and that didn't work either. So I am pretty confident it is something on the side of the car not the remote. Any Ideas on how I could fix this or what it could be. I would like to avoid the dealership at all costs cause they are such a damn ripoff.
Thanks,
Battery
Old Aug 6, 2005 | 11:21 PM
Stealth691's Avatar
Default RE: Keyless entry
Hey, Did you check the fuses yet, that might be a cause, and its one of the cheapest routes to go first best of luck.
Old Aug 7, 2005 | 03:55 PM
Battery's Avatar
where are the fuses and how do i check them?
Old Aug 7, 2005 | 04:23 PM
Stealth691's Avatar
Should be somewhere tucked under the driver side dash, down low and you could always check the owners manual. you can buy a cheap fuse tester for about 5 bucks and you just put it to the fuse and a green light will come on if the fuse is good if the fuse isnt it wont light up.
Old Aug 8, 2005 | 05:11 PM
wicked_outlander's Avatar
yeah check your fuse...if anything else fail, then it need's to be re-programmed. (most likely a dealer ship option)
Old Oct 27, 2005 | 02:19 AM
93Miata's Avatar
If you need to get new remotes, try this:
https://www.thepartsyouneed.com/disp...productId=1553
I got mine for my 99 from there.
bushwe
Apr 18, 2005 04:35 PM
tmh1
Nov 20, 2004 10:32 AM
Flipz
Oct 21, 2004 12:39 AM
matt03es
Jul 29, 2004 03:06 PM
mit_ucla
Nov 5, 2003 07:40 PM
