keyless entry alarm ???
Old Feb 2, 2007 | 01:55 AM
spydergt2001's Avatar
Default keyless entry alarm ???
Well here goes my saga. I purchased a 2001 Spyder Eclipse, seems to be pretty loaded. It did not come with a key fob and my wife has been nagging the hell out of me to get keyless entry. Soooo. I ordered a fob one that only has the lock unlock on it. Went out and followed the instructions as posted and walla...keyless entry accomplished....HOWEVER....now when I shut the car off and open the door, the headlights go into flasher mode for about 2 minutes. Even if I restart the car they continue to flash....to say the least..its rather anoying. So what to do? Is there a relay or fuse to the alarm system that I can disable...any suggestions would be greatly apreciated.
Old Feb 3, 2007 | 02:38 AM
mtdahl's Avatar
Default RE: keyless entry alarm ???
to disable the alarm look under the dash on the drivers side on the firewall. there is a black wire with a white connector unplug it.
your problem should be solved.
mattastik
Apr 2, 2008 12:45 AM
silvercoupe97
Dec 1, 2006 09:20 AM
tmh1
Nov 20, 2004 10:32 AM
matt03es
Jul 29, 2004 03:06 PM
mit_ucla
Nov 5, 2003 07:40 PM
