mechanical question
Old May 24, 2006 | 06:53 PM
doebereman's Avatar
Default mechanical question
so my 2000 GT has this problem and it consists of the heat gauge rises almost to red line and then falls back to normal, as far as i can tell its random, i wonder if the heat gauge is failing. but like a couple minutes after i start the car and it heats up it will almost reach the red line and the fall back down quicker than it rose, i checked all the liquids in the car and there at good levels. what do you guys think?
Old May 24, 2006 | 06:58 PM
Default RE: mechanical question
the fan working??
Old May 24, 2006 | 07:14 PM
magnet's Avatar
thermostat
Old May 24, 2006 | 08:03 PM
eclipsed4u's Avatar
ORIGINAL: magnet
thermostat
Old May 24, 2006 | 08:47 PM
Evil1993Eagle's Avatar
ORIGINAL: magnet
thermostat
yep, replace it.
Old May 24, 2006 | 10:53 PM
Sanguinius's Avatar
ORIGINAL: Evil1993Eagle
ORIGINAL: magnet
thermostat
yep, replace it.
Definately. It's on the way out and njot much longer before it won't open at all. Then you'll overheat and blow the head gasket BAD times!!
Old May 26, 2006 | 05:20 PM
doebereman's Avatar
fan does work, ill check into getting a replacement thermostat. I was thinking thats what it was but wanted others input before i did anything. thanks
Old May 27, 2006 | 01:53 AM
So did you replace the thermostat? How is everything working now?
Old May 27, 2006 | 06:21 AM
GuidoSalducci's Avatar
yes def a thermostat, or possibly the wiring
Old Dec 31, 2006 | 11:20 PM
clee's Avatar
Anyone havea link to how i can replace the thermostat in a 1999 eclipse? I've never done a thermostat install before.I saw a few posts that there were 2 types, one that opens at 180 and at 192, any suggestions as to which is right?I just bought the car and it isn't blowing hot air even though the temp gauge is at the halfway point. Before I move to troubleshooting the heater core I'd like to try the cheap fix first. Thanks for the help!
