mystery noise
Old Mar 17, 2014 | 08:27 AM
doofusmagee's Avatar
Default mystery noise
hello all you wise and helpful people out there. (and i mean that in the most hopeful way.) my daughter recently bought a '04 gts spyder, and it is a beautiful car! unfortunately, she fell in love with it before i had a chance to see it or drive it. when i did drive it, i heard an ominous thumping sound out of the passenger side floor board sounding just like a single loose big end bearing. i replaced all of them, but the noise persists. sounds like a bearing, and tracks with rpm, but when i listen directly to the motor, i hear nothing but the usual clicks and whirrs. this is not a quiet car as the engine sounds like it's bolted solidly to the frame. if anyone has a clue, i could use one. thanks
Old Mar 18, 2014 | 08:24 AM
jkeaton's Avatar
Sorry, kinda hard to diagnose a noise over the computer. Not sure what you mean by a "single loose big end bearing", but I would inspect the CV joints, tie rods, etc. Anything related to the front end. Seeing how you say it follows RPM, I would lean more towards CV joints.
Old Mar 18, 2014 | 11:26 AM
it does it in park and while driving and follows engine rpm.
Old Mar 18, 2014 | 12:36 PM
jkeaton's Avatar
So what do you mean by the big loose end bearing and what did you replace?
Old Mar 19, 2014 | 09:34 AM
not big loose end bearing. loose big end bearing. that's the bottom, or big end of the connecting rods.
Old Mar 19, 2014 | 10:34 AM
jkeaton's Avatar
I'm just trying to understand what you have done so bear with me. You have torn the engine down and replaced the connecting rod end bearings and the noise is still there. Hopefully you didn't pay some one to misdiagnose the issue. So we can rule out rod bearings. OK, how about the accessories (PS pump, AC pump, etc) Timihng belt, idler pulleys, water pump...all driven by the engine. Those been checked? How many miles on the car?
Old Apr 9, 2014 | 12:53 PM
thanks for the reply, and nope, i was able to misdiagnose it all by myself. however, while poking around under the car with the engine running, i did find the source of the noise. the fuel pump! yes i do feel stupid, but it mimmicked a loose rod perfectly. pulses from the pump are travelling down the line and everywhere there's a bracket it transfers to the body. is this the fuel pump wearing out?
PH Smith
Sep 18, 2011 09:32 PM
vinel
Jul 5, 2010 09:23 PM
3000gt16
Nov 27, 2009 05:53 PM
3000gt16
Aug 30, 2009 10:58 PM
tjbiker031
Sep 12, 2007 11:06 AM
