Need help rebuilding engine in 2002 RS
Old Oct 31, 2015 | 12:40 PM
leen's Avatar
Default Need help rebuilding engine in 2002 RS
Have spun bearing and found it chewed up on oil pan ... so rebuilding engine so have few questions.. please note that when I was moving crankshaft manually it was still making hissing sound so I believe compression should be ok..??correct me if am wrong.
1. which brand rod and main bearing set I should buy? or does it matter if I buy on eBay ...just generic brand?
2. Should I buy standard size bearings set or littler over sized? I don't think anything wrong with pistons
3. should I take block to machine shop to figure out what else is anything wrong with it?I know u would say but it costs a lot of money...so wondering if its really necessary?
4. Can I reuse head gasket and bolts?
5. Should I change rear main bearing seal set as well ..if so again any brand on eBay ?
6.Any other suggestions?
buffboettcher
Dec 9, 2012 11:53 AM
mmalone4.16
1st Generation
Apr 28, 2011 03:41 PM
proudnavyaowife
Dec 4, 2009 09:11 PM
95 Montero LS
Jun 13, 2006 03:14 PM
KillerEclipse
Apr 29, 2005 11:20 PM
