new owner of 3g eclipse gt.... question
Old Jan 9, 2015 | 07:50 AM
Jamaican Pride's Avatar
Default new owner of 3g eclipse gt.... question
New fuel pump just went in, car cranks but there's no start.
Located fuel pump relay, is it common for the relay to be bad?
vehicle has 140k miles, everything appears to be original.
planning to check for spark today.
any info or common problem knowledge would be much appreciated.
Old Feb 16, 2015 | 07:04 PM
Semulater's Avatar
This is the Multi Port Fule Injection pump relay check for 2000 - 2002 eclipse/spyders. you only need and OHM meter to check it.
Old Feb 16, 2015 | 07:09 PM
Semulater's Avatar
This is the location of said relay
Old Feb 16, 2015 | 07:13 PM
Semulater's Avatar
if you don't have a scanner you can get them for as little as $20 on ebay or just rent one at your local AutoZone, the rental is free you just give them the equivlant $ value and you get it back when you return it.
Zequel
Dec 26, 2014 01:40 AM
IndyEndeavor
Jan 10, 2013 07:01 AM
Tmats811
Apr 30, 2011 09:59 PM
kornfandude
Jan 5, 2010 10:16 PM
rgsoundguy
Aug 15, 2008 12:00 PM
