OBD Code 420 for catylatic converter
Old Mar 11, 2008 | 12:21 PM
dsm1990gsx's Avatar
Default RE: OBD Code 420 for catylatic converter
ORIGINAL: asim281
ORIGINAL: dsm1990gsx
p0420- is cataylitic converter below threshold, which means you need a new cataylitic coverter.
I don't think it means I need a new Cataylitic converter right off the bat. There are many reasons as to why this code can appear. Catalyst efficiency low-bank 1 is the meaning off P0420. The oxygen sensors monitor the cataylytic converters ability to store oxygen. Probable causes:
1. Engine misfire or running condition
2. Large vacuum leak
3. Engine oil leakage into exhaust-valve guide seals
Trust me as long as your o2 sensors are switchig you need a cat.
#1 and #3 will cause a cat to go bad and #2 will not give you a p0420 or p0430. You get either o2 codes or bank 1/2 lean codes.
roccu
Jun 4, 2009 05:49 AM
Stryker
Sep 16, 2007 08:36 PM
Catch22!
Sep 3, 2007 07:08 AM
ajav05
Oct 1, 2006 02:32 PM
hussain74
Aug 24, 2006 09:34 PM
