Performance brakes, pads & rotors for your Mitsubishi Eclipse 3rd generation
Old Oct 3, 2014 | 06:44 AM
carid's Avatar
Former Sponsor
Arrow Performance brakes, pads & rotors for your Mitsubishi Eclipse 3rd generation
Brake rotors can wear unevenly or become slightly warped over time, compromising your braking performance. Upgraded components ensure both quicker acceleration and quicker stopping time.
When looking for new high-quality replacement brake pads, it is better to choose a product that will surely serve all your needs. Being the most expendable vehicle part, brake pads should be the most hardy of the hardy to live a longer life. The redstuff ceramic brake pads by EBC will offer OEM quality fit and operation with the superior stopping power, longer life, reduced brake fade.
Low dust brake pads by EBC:
http://www.carid.com/2000-mitsubishi-eclipse-brakes/ebc-redstuff-ceramic-brake-pads-4216826.html
* Ceramic pad compounds wear slower and last longer than OEM equipment;
* Eliminate squealing under the extreme cold or hot temperatures;
* 6 month/10,000 mile manufacturer warranty against premature pad wear under normal driving conditions;
Vehicle brakes are vital to your safety when driving. All the performance brake kits, rotors, and pads feature precise fit for a trouble-free installation and the highest quality possible for years and miles of reliable service.
1-click vented brake kit manufactured by PowerStop:
http://www.carid.com/2000-mitsubishi-eclipse-brakes/powerstop-1-click-brake-kit-4049473.html
High-quality brakes go hand in hand with driving safety. Brembo, KSport and Wilwood are gods in brake industry. They offer all kinds of high performance calipers, brake pads and discs.
You can read more information about KSport at CARiD.
The following video also will give you some information about KSport company:
Brake kit created by KSport:
http://www.carid.com/2000-mitsubishi-eclipse-brakes/ksport-procomp-brake-kit-15217874.html
* All components are designed for bolt-on replacement without modifications;
* Aluminum caliper pistons provide freedom from corrosion, better heat resistance, and lighter weight;
* All caliper seals are heavy duty for sustained high-temperature racetrack use;
* 1-year manufacturer warranty;
If you are not up to upgrade the performance of your Mitsubishi Eclipse, just take a look at caliper covers designed by MGP. They definitely will help you to upgrade the appearance of your OEM calipers.
Follow the link to see more custom caliper covers for your Mitsubishi at CARiD.com:
http://www.carid.com/mgp/custom-caliper-covers.html
Which option is the best for you: performance brakes or caliper covers?
Old Jan 6, 2015 | 09:56 AM
carid's Avatar
Former Sponsor
Braking industry is very important, that's why PowerStop is here to cover you up and provide the best solution for your vehicle's braking problem. We are very proud to announce new 1 click brake kits created as a result of cooperation of Bondurant and PowerStop. The partnership of these companies means that they cooperate to improve and advance their products even more.
Check out this video, it will give you general idea about the legendary Power Stop and Bondurant breakthrough partnership:
Power Stop makes both slotted and cross-drilled rotors. There are distinct advantages to drilled rotors which is why many superb vehicles like Corvette, Mustangs, etc. come equipped with drilled rotors.
Here at CARiD we also offer a range of Power Stop ceramic brake pads, drilled/slotted rotors, and related components providing all the benefits of superior materials and OE quality fit.
Read more about the manufacturer here: http://www.carid.com/powerstop/
Old Mar 18, 2015 | 07:58 AM
carid's Avatar
Former Sponsor
Hey guys,
CARiD is here again. Wanted to share some AWESOME news with y'all!
10% discount is available on all Powerstop products, such as Brake Pads, Brake Rotors, Calipers, Pad Wear Sensors, Brake Kits and Caliper Kits!
Hurry up the promo is valid from March 1 till March 31, the prices on our web-site are already reduced.
msport_2_outlander
Jan 9, 2015 07:30 AM
ultrarevvin1
Jan 14, 2014 10:38 AM
ultrarevvin1
Jan 11, 2014 07:13 PM
BEAT
Sep 8, 2008 09:35 AM
xAbre1200
Dec 16, 2007 12:31 AM
