question about turbo 3g... again
Old May 14, 2008 | 12:02 AM
1fastSPYDER's Avatar
Default question about turbo 3g... again
so ive been looking around to put together a turbo kit and ive read in the forums that the 3g GT needs a 20g turbo but some say a 16g would work fine... ive also seen TONS of t3/t4 kits but it says they are made for the 4g63... even tho this may be a dumb question.. is it possible to install the kit for the 4g63 and what components would have to be swapped to be functional on the GT???
Old May 15, 2008 | 01:43 PM
bestwiseguy's Avatar
Default RE: question about turbo 3g... again
the 16g ,20g, and t3/t4 are only referancing the size of the turbo, depending on the amount of power you want will determine which turbo to use. What are your goals for this car, and please tell me you are also buying the supporting mods to safely turbo your car?
Old May 15, 2008 | 01:47 PM
estraw's Avatar
you know with stock internals you will only be able to run i believe 8 or 9 psi at best. its not common to turbo the v6 3g's because of that. it is by no means an easy/inexpensive project
Old May 15, 2008 | 09:26 PM
and to answer no you cant put a 4g63 in.
Old May 15, 2008 | 11:19 PM
Dusty Eclipse's Avatar
Its also probably not the best idea to boost a 6g72.
klas
Jan 16, 2010 12:58 PM
hnoppenberger
Dec 24, 2007 09:48 PM
sleepingGS
31
Jul 6, 2006 10:42 AM
TheEngineer
Apr 17, 2006 11:55 PM
micahman
Mar 2, 2006 11:15 PM
