Random Ticking on Startup
Old Dec 30, 2007 | 09:15 AM
EclipseGT80's Avatar
Default Random Ticking on Startup
I have a 2003 Eclipse GT 3.0 and when i start it up it starts ticking for about 30 seconds. On every startup it ticks for a different amount of time. Sometimes it doesn't even tick at all. I notice that if it sits for a longer period of time then it will tick longer. I've been told that it is most likely my lifters. If it is my lifters do i need to replace them or clean them. Can it be a do it yourself job or should i leave it up to an automechanic. Could it also be a blockage in my oil flow because ive never really checked. Is there anything i can put in my oil to get that out if there is any. It seems to only do it mostly when its cold out, thats when i notice it the most. It is so annoying and very embarassing. Any Suggestions? Thanks!
Old Dec 30, 2007 | 09:47 AM
Default RE: Random Ticking on Startup
Its your throw out bearing. Its perfectly normal on those cars... for some reason they are really loud.
Nothing to worry about.
Old Jan 2, 2008 | 01:39 PM
smeredith11's Avatar
i have the same problem.. apparently its normal w/ these cars.. everyone ive talked to said its the throw out bearing.. they say its nothing to worry about.. but mine goes away when i press the clutch down.. does urs?
cerberus9
Sep 18, 2017 11:16 AM
Lightman
Mar 27, 2008 09:53 AM
Raptors
Sep 5, 2007 11:47 AM
XBMRX
Jun 15, 2007 11:15 PM
Wagoner
Feb 3, 2007 12:41 PM
