Removing Tape Adhesive Safely
Old Oct 15, 2005 | 02:56 PM
pratzert's Avatar
Default Removing Tape Adhesive Safely
I just bought a 2002 GT and the dealer had several papers actually taped to the inside of the Rear Window with scotch tape and masking tape. Ya... on top the the defroster heating grid.
What can I "SAFELY" use to remove the adhseive without harming the heating grid strips ?
Thanks, Tim
Old Oct 15, 2005 | 03:12 PM
Sanguinius's Avatar
Default RE: Removing Tape Adhesive Safely
Try either Nail polish remover or rubbing alcohol. Just be careful not to spill it LOL I'd say soak a cotton ball in it.
Old Oct 15, 2005 | 11:55 PM
crunchie's Avatar
I'd go with the alcohol or even soapy water. Just get a piece of cloth damp (not soaking) with it and rub it away with moderate force. It you have to push real hard, you need more alcohol or soapy water. You can get the rubbing alcohol from any drugstore or even grocery store.
I wouldn't use nail polish remover. It stinks and seem harsher than regular rubbing alcohol.
Old Oct 16, 2005 | 12:34 AM
Sanguinius's Avatar
Yeah but depending on the type of tape they used the acetone may be required to get it off the alchy might not be enough. But try the alchy and elbow grease idea first it'll be the less harsh way to do things.
Old Oct 16, 2005 | 12:42 AM
pratzert's Avatar
I'll try the soap first, then the rubbing alcohol, then the acetone/nail polish remover.
What type of adhesive do they use to stick that defroster grid on the window ?
Something that won't be affected by acetone ???
Tim
Old Oct 16, 2005 | 01:05 AM
Sanguinius's Avatar
It should be basically painted on if I'm not mistaken but I really don't know. I'm fairly certain the Acetone shouldn't affect it but I'd definately try the least method first I doubt soap n water'll work.
Old Oct 16, 2005 | 09:25 AM
wicked_outlander's Avatar
warm water w/ soap, then use alcohol after.
Old Oct 16, 2005 | 01:36 PM
Lil red's Avatar
What about something like goo gone? supposed to remove sticky film like things... Isnt too hard to fine walmart or meijer has it.
Old Oct 16, 2005 | 04:29 PM
Sanguinius's Avatar
You could try that too. I dunno what effect it'll have on the heating element itself but hell it's worth a try. Personally I think the dealership that was STUPID enough to use tape on the window should be responsible for getting it off.
Old Oct 16, 2005 | 04:30 PM
Lil red's Avatar
They should take off there stupid dealer stickers off the rear bumper while there at it...[:@]
