Suspension Suggestions...
Old Mar 17, 2006 | 09:57 PM
Eclipsor's Avatar
Default Suspension Suggestions...
I have the 2001 Spyder GT with 73K Miles...
I thought to install the front sway bars to stiffen up the front... but I read in another post that I will not see much improvement unless I include a whole set of springs and bushings... I am looking to smooth out the front end.. it feels as thought the front end is heavy.
THanks for any advice... I am loving this car.
Old Mar 17, 2006 | 10:05 PM
Default RE: Suspension Suggestions...
Eibach springs with KYB agxs camber kit all around then your sway and strut bars and youll be taking corners fairly well....motor mounts also will help out too
Old Mar 17, 2006 | 10:23 PM
Eclipsor's Avatar
Will replacing the mounts and springs be a mountain of work?
Old Mar 17, 2006 | 11:53 PM
ORIGINAL: Eclipsor
it shouldnt be bad...if you know how to do any of it that is. I mean if you do the springs and shock\struts you will only be pulling out old and in with the new rather than just springs where you need to pull it all out and put the new springs in over the old stuff
Old Mar 18, 2006 | 02:43 PM
ORIGINAL: Eclipsor
To replace the springs you will jsut need to get the tool for it which you can rent from autozone
Old Mar 18, 2006 | 03:04 PM
ORIGINAL: TheEngineer
ORIGINAL: Eclipsor
your gonna need more than just that one tool
Old Mar 18, 2006 | 06:02 PM
well yea but i was just making note that it is important to know that. Smart ***.
3KGT
Jul 24, 2005 01:40 PM
...GTSL...
Jul 18, 2005 06:53 PM
Ishibustim
Feb 12, 2005 03:37 PM
FatalJRA
Dec 19, 2004 06:55 AM
Prophet
Aug 6, 2004 07:22 PM
