Traction...
Old Dec 11, 2005 | 11:38 PM
sunshinee's Avatar
Default Traction...
Question..... Is there anyway to turn traction control off on the GTS model ...3G?
Old Dec 11, 2005 | 11:50 PM
Default RE: Traction...
do they even have TCS?? those cars have the worse tration of all time.... BTW if you arewanting to spin your tires you will crack you daskboard up by the windsheild, all 3G Eclipses do that both of mine did and on top of that the motor mounts really suck and will wear out quickly
Old Dec 12, 2005 | 12:39 AM
eclipsed4u's Avatar
just replace the motor mounts with firm ones from deyeme and you will eliminate most of the wheel hop.
PS....STOP DROPPING THE CLUTCH AND YOU WON'T SPIN
Old Dec 12, 2005 | 12:54 AM
ORIGINAL: eclipsed4u
motor mounts do work wonders with the 3Gs they suck for traction.
Old Dec 12, 2005 | 02:26 PM
sunshinee's Avatar
Actually I was just having some fun in our first snow strom here in Jersey . And yes the GTS model does have TC, but not a switch for it, at least not that I know of.
Old Dec 12, 2005 | 03:09 PM
eclipsed4u's Avatar
i don't believe you can turn it off. but you must have one of those special GTS'....b/c i think you are the first with traction control.
Old Dec 12, 2005 | 06:23 PM
Ya I have honestly never seen one with TCS and I have been around 3Gs sincs 01... that doesnt mean anything though. and if you insist that you have it look in the owners manual at the fuse panel layout I know supra guys turn it off by pulling out its fuse.
But like I said I really dont think they had TCS do you have some sort of TCS light that comes on when spinning or on startup? again I have never once heard of it on any 3G
Old Jun 9, 2018 | 12:54 PM
Kevin Cox's Avatar
I know this thread is old but yes they do have traction control and yes i would like to know a way to disable without hurting anything
johvig
15
Dec 9, 2007 12:15 AM
Boost_Bandaid
Dec 4, 2007 08:02 AM
vinceaton
Jun 11, 2005 01:16 PM
xtremeone1998
Apr 5, 2005 12:21 PM
xtremeone1998
Mar 25, 2005 08:57 PM
