Vacuum Leaks
Old Aug 25, 2018 | 04:08 PM
Widgmaster's Avatar
Default Vacuum Leaks
Having trouble with a vacuum leak and can`t find it . Here is a simple solution .. I took a clean paint can and put a screw in valve stem in the side.. On the lid I put a hose nipple . The tire compressor I use I bought at Canadian Tire but you guys from the States could get one from Auto Zone or your choice of Automotive Suppler. As you can see in the pictures I lined the bottom of the paint can with aluminum foil . You take some barbeque bricks and heat them with a propane torch and place them in the can with barbeque tongs .Tear up some cardboard and place in the can and put the lid on . Use a spare hose line ( it must fit your nipple and some where on your vacuum on your car ) Hook up the valve stem to about five pounds of air... Make sure you close up the intake where its introduced at the air filter. This will fill the system with smoke and it will leak out where your vacuum leak is... Hope this helps some body.. It saved me a few bucks and now I have a smoke machine of my own...
Attached Thumbnails Vacuum Leaks-smoke-can-1.jpg   Vacuum Leaks-smoke-can-2.jpg   Vacuum Leaks-smoke-can-3.jpg
Paquita13
Jun 14, 2013 02:34 PM
Catch22!
Aug 22, 2007 09:50 PM
KirstenLaBarb
Nov 27, 2006 09:32 PM
shooster
Sep 8, 2005 08:02 PM
mike350z
Jul 16, 2004 09:22 PM
