What Vin's make a GT Fed spec
Old Mar 28, 2008 | 03:17 PM
Camel3g GT's Avatar
Default What Vin's make a GT Fed spec
Wondering what vin number is the fed spec eclipse gt
Old Mar 28, 2008 | 03:59 PM
Default RE: What Vin's make a GT Fed spec
Please sticky....
Fed Spec
Fed Specs only affect 2000 and some 2001 models, Manufactured from August 1999 to late October of 2000, these GTs came with 205 hp and 205 ft·lbf. The Fed Spec GT is most recognizable for having one catalytic converter (cat) and two O2 sensors, with one sensor before the cat and the other after.
Cali Spec
Cali Specs in 2000 were primarily shipped to California because of the more stringent emission laws; although other areas of North America received them as well. The Eclipse GT line was switched over for cost reasons to the Cali Spec, so only one version of the GT would be manufactured. Cali Specs came with 5 hp less and 5 ft·lbf less. Cali Spec emissions control are three catalytic converters and four O2 sensors. After each exhaust header is a sensor followed by a pre-cat then the main cat after y-pipe then two more O2 Sensors.
Advantage/Disadvantage
1: The most notable advantage for the Fed Spec is with power gains with aftermarket accessories, i.e. exhaust headers, air intakes, cat-back exhaust systems, and moderate forced induction applications.
2: Whereas the Cali Spec has the aftermarket dominated, with five years in production it would make since to make products for Cali Spec, being the dominant trim. A good example would be headers, for those with Fed Spec you will find yourself adding 6-10 inches to a cat-back and plugging two O2 sensor bung holes to fit.
Note: The GTS is Cali Spec, the power increase is from raising the compression from 9.0:1 to 10.0:1 and adding equal length runners with butterfly valves. Forced induction applications with stock short block over 5-6 psi have proven engine failure.
http://www.club3g.com/forum/3g-eclip...cali-spec.html
Old Mar 28, 2008 | 04:02 PM
Camel3g GT's Avatar
Hence me having a 00', so i suppose im running with a fed spec.
Old Mar 28, 2008 | 05:47 PM
PoolhallJunkie777's Avatar
so when i am redoing my exhaust can i take out two of the cats and just use one that follows the headers? or do i have to get three cats when i am getting my headers?
Old Mar 28, 2008 | 05:57 PM
taking out the cats will threw a check engine light and make your car emmisions illegal
Old Apr 2, 2008 | 11:47 PM
ArchaicDSM's Avatar
So you all know, you can just pop the hood and look at the emissions sticker on the underside of the hood. It will say, "This vehicle conforms to all Federal and California...." or all federal... or whatnot. all cars since '75 have had them.
Additionally, all the cars discussed in this forum (excluding diesel...) will have two oxygen sensors, the one on the header side being the 'pre-cat', or 'upstream', and the one afterward being the 'post-cat', or downstream. This is done to measure the efficiency of the cat, as the sensors report the 02 entering and separatly leaving the catalyst. dont expect to be able to differentiate any model from any other by the positioning of the 02 sensors.
budh
Oct 6, 2023 01:35 PM
rdenis
Jul 29, 2012 02:11 PM
Valerie
Aug 15, 2007 10:04 PM
ictponder
Mar 21, 2006 10:03 AM
Silvertooth
Oct 19, 2005 08:34 AM
