windows issue
Old Jul 8, 2008 | 09:31 PM
maonike's Avatar
Default windows issue
please i need help really bad my windows are not working i have a mitsubishi 2000 2.4L when i try to open the windows from the driver side it does not work any of the two windows but when i try to open the passenger window with the passenger bottom it does work can someone please help me.
Old Jul 9, 2008 | 11:54 AM
estraw's Avatar
Default RE: windows issue
you probably need a new window switch on the drivers side. only way to be sure is to take a multimeter and start probing around
Old Jul 10, 2008 | 12:29 AM
maonike's Avatar
I'm really sorry but what is a multimeter and how could i check that out? Thank you for answering my question
Old Jul 10, 2008 | 02:44 PM
BEAT's Avatar
It is a meter with positve and negative and with a gauge on the top. to check onwiring if they are still working or not. It is usually used by electrician to test the wirings if theyare dead etc etc.
you must have ashort on the wiring on the driver side. or just take out the door cover and speaker and try to play with it. if you dont know I recommend to find a Automotive Electrician or regular techinician with knowledge on power windows at least your passenger side button works.
or Change the master button on the driver side.
jniesen
Feb 16, 2013 05:19 PM
305RS97
Oct 1, 2005 01:53 AM
Red97EclipseGS
Aug 11, 2005 02:36 PM
l200luke
Jul 4, 2004 01:11 PM
dbeaver
Sep 27, 2003 09:51 PM
