windows issue
please i need help really bad my windows are not working i have a mitsubishi 2000 2.4L when i try to open the windows from the driver side it does not work any of the two windows but when i try to open the passenger window with the passenger bottom it does work can someone please help me.
It is a meter with positve and negative and with a gauge on the top. to check onwiring if they are still working or not. It is usually used by electrician to test the wirings if theyare dead etc etc.
you must have ashort on the wiring on the driver side. or just take out the door cover and speaker and try to play with it. if you dont know I recommend to find a Automotive Electrician or regular techinician with knowledge on power windows at least your passenger side button works.
or Change the master button on the driver side.
