OEM HID to Halogen Rewire / Conversion or Part Source
Both headlight assemblies on my 2010 Eclipse sprung leaks and corroded the OEM ballast connections in the HID headlights. I successfully repaired the RH assembly but destroyed the LH assembly, trying to get it apart (Don't ask). I've researched this issue for several months since the RH unit sprung a leak and corroded. I've yet to find a solution. I need:
- A source for a replacement HID headlight assembly, drivers (left) side, OR
- A procedure for wiring halogen headlight assemblies in an HID headlight Eclipse.
fiestataz
06-26-2012 05:18 PM
