Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
added rca outputs to my stock infinity amp
Old Jan 18, 2006 | 01:13 AM
noremacyug's Avatar
Default added rca outputs to my stock infinity amp
alright, after deciding to put the sub i pulled out of my truck into my 00 eclipse i was determined to have rca jacks and to have an actual remote on/off to turn my amp on/off with the radio and not when the ignition is turned on. so, i ripped out my seat and pulled the amp out and then tore into the amp. i then simply soldered some rca ends onto the circuit board where the din cable connector comes in. i also soldered a wire to the remote wire pin from the din cable connector which gives me a 6v signal on that wire. im going to use that 6v to hook up a low voltage trigger that will give me the 12v i ned for the remote wire hookup on my aftermarket amp. i got it all hooked up and temporarily applied 12v right from the battery to the remote hookup to test everything out. it all works perfect. i put the sub onto the rear channels and so far im happy with the results and the fact that i can keep my stock stuff while having the much needed bass from the sub.
[IMG]local://upfiles/6423/EC9367626F8F4A4999D3D2FF82BA5C20.jpg[/IMG]
[IMG]local://upfiles/6423/56F6B6E44DB34CF58298CAC26F6A6232.jpg[/IMG]
Old Feb 7, 2006 | 06:38 PM
anko_kun's Avatar
Default RE: added rca outputs to my stock infinity amp
that is kool
chaser9478
Dec 12, 2012 07:06 AM
ictponder
Dec 23, 2006 09:14 AM
ictponder
Dec 11, 2006 10:30 PM
5Tizzle
Nov 25, 2006 03:47 AM
MrJayDeeOne
Mar 25, 2006 04:38 PM
