Amp Installation help!!!
hey guys,
ok i need help installing my 2 amps....my head unit only has one set of RCA behind it so im having trouble installing both my amps...i going to run one amp 2 my speakers, and the other amp to my 2 subs!! i bought 2 y-connectors but i dont understand how to use them....thnx guys
I suggest gettin a RCA converter for your speakers you hook the amp up and then attach the speaker wires to the amp
then the rear speaker wires you attach to the rca converter (it shows a diagram when u buy it) then u hook that amp to the putputs on the RCA adaptor..
Then you just hook the amp for your subs up and just put it to the outputs in the front hook speaker wires from sub to amp then hook speaker wire from speakers to other amp and then ur good to go
if im wrong with somethign or theres an easier way please assist cuz im only 16 so not much knowledge but i belive this will work
CoolJayz18
Sep 22, 2018 07:57 AM
