Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Amp Installation help!!!
Old May 31, 2006 | 06:49 PM
nawgee's Avatar
Default Amp Installation help!!!
hey guys,
ok i need help installing my 2 amps....my head unit only has one set of RCA behind it so im having trouble installing both my amps...i going to run one amp 2 my speakers, and the other amp to my 2 subs!! i bought 2 y-connectors but i dont understand how to use them....thnx guys
Old Jun 1, 2006 | 01:23 AM
xXx Galant xXx's Avatar
Default RE: Amp Installation help!!!
I suggest gettin a RCA converter for your speakers you hook the amp up and then attach the speaker wires to the amp
then the rear speaker wires you attach to the rca converter (it shows a diagram when u buy it) then u hook that amp to the putputs on the RCA adaptor..
Then you just hook the amp for your subs up and just put it to the outputs in the front hook speaker wires from sub to amp then hook speaker wire from speakers to other amp and then ur good to go
if im wrong with somethign or theres an easier way please assist cuz im only 16 so not much knowledge but i belive this will work
CoolJayz18
Sep 22, 2018 07:57 AM
CarlisleP&SPaddy
Jan 26, 2010 10:32 AM
BrianWSNC
Oct 16, 2008 08:22 AM
mlevasseur
Sep 14, 2008 12:21 PM
