Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Navi Video Input Question
Old Nov 25, 2008 | 05:31 AM
xarons21's Avatar
Default Navi Video Input Question
I have a 2008 Lancer GTS with the stock navi unit but NO sun and sound package... so I do not have the RCA plug in for audio and video. Question is can I add a video input like I did with audio with a plug in addon? if not does anyone know the wires I have to splice RCA wires into or if that would work? Basically what can I do to add video input =)
Thanks guys!!
Old Nov 25, 2008 | 07:15 AM
mitsupartsman.com's Avatar
Default RE: Navi Video Input Question
you need p/n 8750A047 adapter with audio and video inputs.
search this board for anything related to the MMCS you'll find theres alot that unit can do.
Old Nov 25, 2008 | 08:13 AM
xarons21's Avatar
Thanks so so much man I appreciate it much!!!
I normally do search first, but being at work, makes it rough, gotta be quick on and off with the internet.
Thanks again!
Old Dec 10, 2008 | 12:05 PM
xarons21's Avatar
OK I have the connector.... but how do I use it, it didn't come with a cable, is that piece seperate??
Old Jan 13, 2009 | 08:36 AM
xarons21's Avatar
/bump please help!!!
Old Jan 13, 2009 | 05:13 PM
assuming you bought the part (from sombody other than mitsupartsman ) it mounts in the pocket located in front of the center console. if you remove theconsole you will find the plug waiting to be used.
Old Jan 15, 2009 | 06:25 PM
xarons21's Avatar
mitsupartsman sorry for not purchasing this item from you, I will deffinetly keep that in mind next time I need to buy anything for my car.... BUT your seggestion you listed above is not workin out for me.... I took my dash apart and i found nothing..... again my car does NOT have the sun and sound package and did NOT come with the origional RCAs so they probably didnt wire in for mine.... was wondering if there is a rear connector for audio/video like in the Pajero The link below is a guy that said he used a read connector origionally intended for the rear displays in the pajero... so was wondering if the lancer has the same thing. IF not, I need to know where I can get the connector... can you sell me that piece?
If you cant understand this please tell me and we can go abot another way to discuss this.
Thanks so much!!!
https://mitsubishiforum.com/m_232174/tm.htm
Old Jan 16, 2009 | 08:08 AM
you need to find connector # C-121 it is a six pin connector
Old Jan 16, 2009 | 01:24 PM
FAX68's Avatar
The guy who fix his Pajero KNOWS what he was doing He MUST HAVE A DEGREE IN electrical engineering.
The pics seems so easy but in REAL life it is a pain in the Butt.
I recommenda car electrician he will find it for you.
do you really want to put a hole on your dash.
manny
May 19, 2009 12:35 PM
bleacherbum
Jan 14, 2009 06:45 PM
blueoutlanderinga
Nov 7, 2008 11:00 PM
FUSE
Sep 17, 2008 09:26 PM
mrtn
Sep 27, 2007 10:32 AM
