Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Radio static when revving engine
Old Apr 17, 2007 | 01:51 PM
Lil Evo's Avatar
Default RE: Radio static when revving engine
Check your grounds, replace your plug wires if they're old, make sure all your connections are properly made, and i'd add the iso's if it's necessary.
Old Apr 18, 2007 | 02:26 AM
antlip's Avatar
Could also be cheap bad RCA wires.
Old Apr 18, 2007 | 07:19 AM
silvercoupe97's Avatar
So, here's the rundown...
- Don't use cheap Radio Shack/WalMart/made for home stereo RCAs. You know, those black ones with red and white ends.
- Check your grounding locations. Scrape the paint for a good ground. Use the same size ground wire as your power wire. A seperate ground is another good thing to do.
- Run your power wires (red, yellow, blue) on one side of the car and your RCAs (signal wires) on the other. Oh yeah, ground wires should not be longer than 3 feet.
- Ground loop isolators should be last on your list. The other things should be done/checked first.
..and finally, what stereo equipment do you have? If you got cheap, you get cheap btw. I'm not trying to sound harsh, just stating the obvious. BTW, your alternator should already have a little capacitor attached to it.
Old Apr 18, 2007 | 11:03 AM
Lil Evo's Avatar
It's really just like anything else in the car world, you get what you pay for.
Old Apr 18, 2007 | 11:05 AM
Dusty Eclipse's Avatar
I wouldnt imagine his problem lies within the RCA cables... not that that wasnt useful info... I just dont see how his RCA cables would explain that..
Old Apr 18, 2007 | 11:58 AM
Lil Evo's Avatar
If they're run on the same side as the power wires, it can cause interference. Gernerally it's not noticable if the RCA's are being used to amplify subwoofers, but definetly becomes noticable when you go to amplify your door/deck speakers.
Old Apr 18, 2007 | 12:50 PM
Oh, I didnt know he was using it for something other than subs... my bad.. (shoulda read the whole post, I guess...)
Old Apr 18, 2007 | 07:33 PM
antlip's Avatar
Cheap crapped out RCA cables will produce low singals. We all know a low signal will produce a bad sound. You want to have a good strong set to allow the best singal going to the amps.
Old Apr 19, 2007 | 12:53 AM
Lil Evo's Avatar
ORIGINAL: Dusty Eclipse
No no, I don't think that's the case, I was saying what an improperly run RCA can do.
Old Apr 20, 2007 | 02:40 PM
R3D's Avatar
R3D
Sorry it took me so long to reply. The car in question is a 2002 Mitsubishi Montero, Loaded. Stock radio nothing changed, added or removed, afaik... I will check the ground, Thanks a bunch, and the RCA's should be stock, so i am not sure if it is that or not, but i will check those as well. Thanks all for the input!
P.S. - I was thinking it had something to do with spark plugs, but I can only base that on a loose and remote possibility. I also thought I remembered something about wiring a capacitor somewhere in the engine compartment, but I also seem to remember that was for older model cars, heheh... RCA and ground sound more reliable anyways, lol. Thanks!
Corbul
Jan 8, 2015 08:43 PM
callingdoug
Dec 23, 2014 11:45 PM
Axle jack
Feb 22, 2014 02:18 AM
klemfare
Nov 9, 2010 07:52 AM
peachgurl
Dec 24, 2006 05:13 PM
