Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
radio turns off and on?
Old Nov 10, 2006 | 09:27 PM
toddyfresh's Avatar
Default radio turns off and on?
i have a 1994 3000gt sl and it was already wired for a system when i bought it. so i hooked up 2 punch 10s and a punch 300 amp. everytime the system goes to hit the radio will like skip it and if i turn up the radio too loud itll shut off and come back on. would the problem be a low battery? any help appreciated
Old Dec 7, 2006 | 08:17 PM
98_GstEclipse's Avatar
Default RE: radio turns off and on?
Im not sure if this is it but check and make sure your terminals are both tightened. I had that problem when i put my in dash dvd in. Double check on all your wiring too.
Old Dec 8, 2006 | 02:02 AM
arrivalanche's Avatar
you have a bad ground on the radio harness. pull the radio out and check where the ground wire is running to. you might need to just ground it to a grounded piece of metal.
natalie eclipse
Aug 12, 2009 01:26 PM
ulysses09
May 24, 2009 07:03 PM
johnyredd99
Jan 27, 2008 08:02 PM
ralphanta88
Apr 26, 2007 02:46 PM
dgill
Mar 16, 2004 11:14 AM
