Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
where do i start
Old Jul 19, 2008 | 07:03 PM
travis309's Avatar
Default where do i start
just got an 01 eclipse. i want to install my aftermarket stereo. cd player, amp, subs. my subbox is too big for the minature trunk (its a spyder)and what the hell do i do with the display unit from the factory cd player. leave it there blank or take it out and put something cool there. im thinking about building my own box for my two 12"ers. any ideas for a box? i was just going to wing it and come up with some sort of contraption. thanks guys, im young and learning.
Old Jul 20, 2008 | 09:56 PM
itsme71190's Avatar
Default RE: where do i start
u dont need 2 12s
Old Jul 29, 2008 | 06:27 PM
Lil Evo's Avatar
The Spyders don't give you much to work with, thats for sure. I've done a couple recently, and both were a bit of a trick. If you want 2 12's, building a box is pretty much your only option, and it'll be tight, and may involve removing the convertible top as well as a few panels. I would probably recomend going with a single sub though, simply because it will allow you to keep a little storage space and will be much easier to work around when it comes to installation time.
Old Aug 1, 2008 | 07:55 PM
travis309's Avatar
ok i could go witha 10 or something. but any suggestions for the display unit for the factory cd player. what do you guys do with that thing? if u put in an aftermarket cd player does it just sit up there not hooked up
Old Aug 13, 2008 | 11:17 AM
Lil Evo's Avatar
you do lose your display when you install an aftermarket head unit. to my knowledge there is no way, at least that i've heard of, to keep the display funcional as it's run through the factory radio.
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
