Eclipse Frequently Asked Question Section This section is only for FAQs, not Q&A. If you have an FAQ reply to submit, contact a moderator or admin.
BCS Restrictor Removal
Old Mar 20, 2008 | 11:57 AM
Default BCS Restrictor Removal
**ALL INFORMATION WAS TAKEN FROM vfaq.com**
This is a free mod to do on stock 1g/2g Eclipse GST/GSX that will gain you typically from 1-2psi more boost. The Boost Control Solenoid (BCS) is was controls the stock boost on any 1g/2g dsm. This prevents the car from running strictly off of the wastegate spring. Within the BCS is a small restrictor which restricts mroe air from flowing, thus reducing the boost. This write-up shows how this small peice is removed:
Here you can see the location of the BCS with the intake pipe removed circled in green
Here is a closeup of the BCS
1. Remove the BCS from the vacuum lines
In these 2 pictures you can see the fitting in which the restrictor is located again circled in green
2. Now once you have the BCS out take a screw that can tighten inside the fitting and screw it slowely into the restrictor slightly then pull on it to remove it from the fitting.
Here is a picture of thefitting with the restrictor removed
Here is a picture of the restrictor on the end of the screw
3. Hook the BCS back up and you are done. You have just gained a few more HP for free
TheEngineer
May 4, 2007 02:27 PM
gstTurbo2011
Jul 17, 2006 10:00 AM
edgeofsane
May 15, 2006 06:09 PM
B.e.R.a.T
Mar 13, 2006 11:35 PM
anko_kun
Dec 14, 2005 01:38 AM
