01 Eclipse immobilizer help
Old May 31, 2018 | 07:53 PM
TurboDodgeXVI's Avatar
Default 01 Eclipse immobilizer help
Hi all. I have a nasty situation going on. I'll run you all up to speed. I bought an 01 Eclipse GT. 3.0L/manual. I was told it needed a new fuel pump. Was getting power to the pump but not after. I replaced the pump and nothing changed. I plugged the old pump into the battery and it fired up so it didn't actually need one. Car cranks but won't start. No codes aside from an immobilizer code. Car came with 2 aftermarket unchipped keys. Towed it to a shop, they got a key made from Mitsu with the VIN. They're using a Mitsu machine and key to program it in there. They have the 4 digit code from Mitsu and the program gets to accepting the code and then immediately backs out and shuts down due to incorrect key. They cannot program it, we can't figure out what's going on. There is an aftermarket alarm but nothing that would[SHOULD]cause this issue. It's a Comstar CM3300. This is where we stand. Does anyone have experience here or ANY suggestions? I don't want to rack up a bill by asking them to start tracing all wires for poor wiring. Any leads or suggestions or even bypassing the immobilizer would be excellent.
Old Jan 20, 2022 | 04:43 PM
Justinz01eclipse's Avatar
Default Please help
Please tell me you figured out the issue man. I have have the same car with the same issue the locksmiths key programmer says no key loaded every time he tries to program key I have had two different locksmiths come out and try it both using different keys and neither one of them work or have been able to fix it or get a key programmed8
2000EclipseGS
Mar 24, 2013 03:41 PM
Growl
Oct 3, 2012 01:57 PM
designflaw
Feb 24, 2012 11:40 PM
jb4lcm
Jul 27, 2010 02:42 PM
goldenboy
Jan 3, 2009 04:45 PM
