01 Galant Stalling, low idle
Old Jun 5, 2005 | 04:03 PM
autorok's Avatar
Default 01 Galant Stalling, low idle
It started like a week ago where the idle would drop pretty low and the engine would turn off everytime I'd stop at a light or stop sign. I had my dad check it and we changed the spark plugs, the oil and oil filter, the air filter, and put in a new thermostat and still the same thing. I had a friend from work check it out and said all I had to do was adjust the idle, but wouldn't that waste more gas? I just wanna get my car running smoothly again without getting ripped. Any suggestions on what it could be. I'm all ears.
Old Jun 29, 2005 | 10:32 PM
rhyno's Avatar
Default RE: 01 Galant Stalling, low idle
try a new TPS (throttle position sensor) that solved the exact same problem on my 92 shadow
Old Jul 1, 2005 | 09:58 AM
pc's Avatar
pc
I'd suggest pulling a code before replacing anything. TPS is probably not cheap. It could be something as simple as a vacuum leak or an intake leak after the MAP/MAS.
Old Jul 1, 2005 | 02:33 PM
FireDoc's Avatar
I have to agree with pc here. As he quoted in another post, don't just start throwning parts at it just to see if it works.
montey cosmopolitan
Jun 5, 2015 10:34 PM
TerryB
Oct 18, 2012 07:50 PM
mchandler76
Jan 7, 2012 06:44 PM
Fullysickmitsu
Dec 4, 2007 06:52 PM
cocosun
Aug 9, 2005 01:52 AM
