1995 mitsubishi eclipse GS
Old Aug 30, 2007 | 12:53 PM
soulbond99's Avatar
Default 1995 mitsubishi eclipse GS
Yesterday on the way home from work my check engine light came on. I didnt think nothing of it. Well on the way to work this morning it just died on me. All it would do was turn over. then a couple of hours later it acted like it wanted to start but died. Then I held the gas down just a little and it started right up. What could be the problem...? Someone please help. could it be a cam sensor...?
Old Aug 31, 2007 | 06:55 AM
Default RE: 1995 mitsubishi eclipse GS
take it to autozone and get the code read for you. They do it for free. Make sure to write down the P code and let us know
Old Aug 31, 2007 | 11:22 AM
soulbond99's Avatar
Well I took it to autozone and they hooked it up to the computer and they said there was no problem found. I took it to a guy I know at a dealership (no charge) and they said all was good. Is it possible that something in the coil pack is burnt and when it gets hot it seperates causing to loose fire? How can I check if the crank sensor is bad and not signaling correctly to the spark and fuel? Thanks
alexk002
Mar 10, 2010 11:11 AM
matt02708
May 25, 2007 07:48 PM
hoosierdaddy_87
May 27, 2006 08:43 PM
brandoN^gsT
Apr 25, 2006 03:39 PM
Dragonsaki
May 13, 2005 12:56 AM
