1996 Eclipse Sunroof strangeness...
Old May 18, 2006 | 10:00 PM
DJ_Rais's Avatar
Default 1996 Eclipse Sunroof strangeness...
Hey all, I opened my sunroof up today like normal (100+ degrees here today) and it made a "clunk" sound when it opened. Now when I try to close it it gets to the point where it should come down and close (sunroof is all the way forward or pretty close to it) then it stops and pushes itself open about 3 inches. I did a quick visual inspection and was unable to find anything wrong that I could "see" any ideas?
Regards,
Greg
Old May 18, 2006 | 11:09 PM
DJ_Rais's Avatar
Default RE: 1996 Eclipse Sunroof strangeness...
OK, so on further inspection it seems that a little guide has came out of the left side (I am assuming it was there, because there is one on the right almost all the way in the front (about 3 inches back) that is shaped like _/ and fits into(?) the two main flat guides. Does anyone know where I can find this kind of part?
Regards,
Greg
Old May 18, 2006 | 11:40 PM
nYOfas's Avatar
Did you try ebay, napa, Autozone or anything like that? IF not, I know someone with a parts 96 that amybe I could talk to? Damn tight *** cars when they screw up. Been there for too long. ....damn,......
Old May 19, 2006 | 12:51 AM
paulsavage's Avatar
i have the exact same car, it does that to me every once in a while too, some kind of design flaw i assume. I wouldnt worry about it too much, usually i just open it back up then it will close correctly.
jthorn75
Jun 4, 2012 04:18 PM
MrJayDeeOne
Aug 23, 2007 03:58 AM
gooberkid1231
Apr 5, 2004 06:26 PM
iceyman
Nov 2, 2003 06:26 PM
tjrcs
Oct 7, 2003 04:28 AM
