19t's still collecting dust 93 vr4
ive had this car for about 1 year now and still cant enjoy it. I even have upgrades like 19t's with supporting mods just collecting dust because i dont want to put that stuff on until i get the car running right. right now everything is stock. the car is running rich, it will boost up to about 5-10psi(stock Gage) when the engine is cold and then cut out, after it warms up it just cuts out after it gets to boosting. i can drive it as long as i keep it in vacuum after it is warmed. Ive exhausted all my knowledge and resources and search engines and dont know what else to do it is a 1993 3000GT VR4 77k miles ive put a new fuel pump, plugs, wires, coolant temp sensors both of them,rebuilt ecu, idle air sensor/motor,clutch, master cylinder, and probably some more that i cant even think of right now. ive tryed a boost leak test but cant find all the leaks. i just did a compression test on the front head and it came out to about 120psi on all 3 cylinders i haven't done the rear cylinders yet because i ordered a few gaskets i am going to replace on the throttle body from leaks that i found and i am waiting to get them. the oil is not milky and the coolant is not oily. i always thought that a bad head gasket would have 1 0r two cylinders low but now all of them.i dont know what else to do or what the equal low compression could mean. any help would be much appreciated.
19t, 19ts, 3000gt, 93, boost, buy, coolant, leak, mitsubishi, mods, review, supportung, temperture, test, vr4
