1st gen problems
Old Mar 13, 2006 | 03:42 PM
DaClipsa's Avatar
Default 1st gen problems
my 94 eclipse does not like to idle when it is cold, it seems as soon as put it in neutral and let off the clutch, the rpm's drop and it dies...
Also... at constant speed it misfires, tried replacing plugs and wires, checked coil, any ideas?
Old Mar 14, 2006 | 12:23 AM
slow420a's Avatar
Default RE: 1st gen problems
could be a bunch of things, I am not a 4g63 guy but check your iac.
Old Mar 14, 2006 | 02:28 AM
sounds like maybe a fuel problem. Or maybe a Mass air problem. I would check either or those.
Old Mar 14, 2006 | 06:08 PM
TransAmist's Avatar
Sounds like fuel pressure problems, either from the fuel filter being clogged, or the pressure regulator not fuctioning properly. Try the fuel filter first with some b12 or some lucas. If that doesn't work, have the fuel pressure tested and replace the regulator or pump, whichever is bad.
Old Mar 17, 2006 | 01:36 AM
jc_ride's Avatar
If the engine is cold an it does not want to run but will run fine when it is warm then the most likely cause is the automatic choke.
ucantfckwitme613
May 27, 2008 11:24 AM
ucantfckwitme613
May 26, 2008 08:16 PM
UTREVO
Aug 9, 2006 07:07 PM
Waters411
Jul 8, 2005 11:06 PM
T76 turbo
Apr 2, 2004 06:12 PM
