90 eclipse non/turbo
Old Feb 23, 2006 | 06:37 PM
EclipseDood's Avatar
Default 90 eclipse non/turbo
Can any one help me with a few probs im having with my car?First thing is my back up lights keep blowing (I have bought 2 sets and after 1 or 2 days thay blow)Allso when i turn sharp i loose alittle power and have no clue as to why.I dont know very much about cars as this is my first one but what i do know helps alittle bit lol.Ok here we go......Having some oil leaking from oil filter and a little bit around the valve cover gaskit(gasket?) i had it replaced but some oil still leaks same with the oil filter i had a oil change done and thay replaced that but it still leaks.Any and all help is welcomed ^_^ thanks
Old Feb 23, 2006 | 11:04 PM
daveyk169's Avatar
Default RE: 90 eclipse non/turbo
i have a gsx so i dont know how much diff. your car is, but on mine there is an oil filter housing and if you take it off tehre is an o-ring behind it. i would suggest replacing the o-ring, beacause i had the same problem. as for the valve cover gasket, the only thing i can suggest is make sure your gasket surfaces are clean before putting the gasket on.
Old Feb 24, 2006 | 12:44 AM
Okay ill try that in the morning.......Allso i have a heater prob every time i try to turn it full blast it clicks and wont work unless i turn it one notch below full blast...any one know how to fix that prob?
Old Mar 2, 2006 | 10:07 PM
My93EclipseGS's Avatar
Your heater problem sounds like a worn out switch in the Dash. Find one from the junk yard or try cleaning yours.
As for your lights you might have a short somewhere in the wiring. It will take a while to track it down. I hate electrical prolems cause it can be almost anything.
What direction when you make a sharp turn do you lose power right or left? does it happen in either direction?
Old Mar 14, 2006 | 03:59 AM
it will happen when i turn right or left dont matter wich way.
Old Mar 14, 2006 | 04:07 AM
lose connections somewhere maybe.. I and it moves and shorts out on corners. do you have any after market lighting NEONs headlights tails turn sigs? what about sterio?
Old Mar 18, 2006 | 04:37 PM
Nope nothing.....I have been working on the engine from the time i got it (replaced a valve cover seal,Doin oil change's,Trying to find out where it leaks stuff like that ^^) still need to get 2 parts befor i can even set a stereo inside my car.All lights are stock (from what i know of)
theironman
Apr 1, 2010 05:57 AM
blitzsuperstar
May 6, 2009 05:12 PM
zeanimal2001
1st Generation
Jun 17, 2007 01:12 PM
blitzsuperstar
Aug 21, 2004 07:37 PM
turbotalon95
Jun 29, 2004 02:38 PM
